Recently I upgraded from Houdini 10.0.xxx 64 bit to 10.0.465 64 bit (all running on Windows Vista 64).
I had made a model in the previous version and locked a SOP, where prior to this SOP in the network was all the primary geometry in place. I locked it, since it made loading up the scene in Houdini a whole lot faster. The model is fairly large and complex if that matters.
Then I upgraded and opened the hip file back up. However, if I unlock the node, the geometry is broken, about 15 to 20 nodes upstream. More recent versions of Houdini do the same thing, unlock the node, and the SOPs are busted.
Any suggestions on how to fix this? Or am I stuck saving off the locked model as a binary, and then remodeling the busted SOPs from scratch again?
Is this normal for this to happen?
unlocking node breaks geometry
5349 4 2-
- jimc
- 295 posts
- edward
- 8081 posts
- jimc
- 295 posts
- Simon
- 2199 posts
When you MMB on the polybevel node does the group you are using exist and have any members in it? If not you need to track down where that group was created, there might be another warning or error message somewhere else that relates to that group.
- edward
- 8081 posts
