proxy geom drives hires geom with enveloping
   3467   3   1
I'd like to limit the amount of geom used within my rigid simulation. I prefer to use proxies of the original geom to drive (env) the more detailed hi res geom.
Any quick set ups available with Houdini, best way to do this?
TIA
check out the dop import node. it extracts the transforms of dop objects and uses that transforms on primitive group that are named like the dopobjects
You could just tweak the collision geometry settings.
Jobless
sanostol
Would that allow me to adjust the blend between the influences, ie..allowing the hi res geom to bend between those transforms?
