Getting UV coordinates on surface from world space position
   6708   1   0
Is there a way to specify a world space coordinate, and return the UV coordinate on a surface at that point? Maya has a pointOnMeshInfo node that would return this info. I'm just not sure where to look in Houdini.
~Mike D.
try the attribute transfereSOP. it transferes any attribute from one mesh onto another.
when Your first mesh is a ppoint You can use it to look up the uv coordinates closest to this point
Martin
