HScript atjob output
   3751   4   2
Hi!
I'm trying to watch every second for a change in node with a ajob HScript function.
I'm trying to redirect the output of this script to Textport or linux shell (I'm wondering how to do it both ways )
so I'm trying to do something like:
atjob -p 1 opinfo(“/obj/lsystem_object1/lsystem9/”) // but I get no feedback in textport nor in shell
I was trying to connect it with functions such as “unix echo …” or simple “echo…”, but not succesfull
Please about help
Thank you
Edited by - April 5, 2010 19:52:46
danilo2
Hi!
ajob -p 1 opinfo(“/obj/lsystem_object1/lsystem9/”) // but I get no feedback in textport nor in shell
I assume you mean ‘atjob’, not ‘ajob’. I tried some simple things, and I think that command is pretty busted – its parsing is completely borked – put the whole thing into double-quotes, and it ceases functioning!
The problem is that you need backticks, e.g.
atjob -p 1 echo `opinfp(“/obj/somewhere”)`
but the backticks will evaluate now instead of on each itereation. I think this is worth sending in to SESI.
In the meantime, I'd put all your script into a .cmd file and make the atjob command source that cmd script. Note that regular ‘echo’ statements will not work, as the atjob processing is detached from the textport. But doing ‘unix echo’ from within the .cmd file should work.
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
Hi!
thank you very much! (of course atjob not ajob )
I'll inform SESI about this problem.
Could you please explain one step of the ‘meantime solution’:
“…and make the atjob command source that cmd script.”
Thank you
danilo2
atjob -p 1 source /my/path/myscript.cmd
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
ah ok than you!
