visibility of parms in multiparm
   5393   8   1
Hi!
I've got a python script:
o = hou.node('/obj/metaSculpter31')
#p = o.parmTuple('_sculptCurLayer')
p = o.parmTuple('sculpt_layerName1')
parm_template = p.parmTemplate()
parm_template.hide(True)
ui = o.type().definition()
ui.replaceParmTuple(p.name(),parm_template)
And It works with the name ‘_sculptCurLayer’ - it hides parm with this name.
But it doesn't work with parameters, that are stored in blocks of Multiparm block - is it possible to hide/show parameters in multiparm block?
thank you
just to clarify. do you mean the parm for all entries or just a single one in your multi-parm?
just single one
as far as I know it's not possible to modify a instance of a parm in a multi-parm.
ou
Will it be added in next versions? or should I send rfe?
You can always submit RFEs for features, however they may not always get implemented.
Having other RFEs for multiparms I'm inclined to say this is probably quite difficult. Currently you cannot even manually hide a parameter even through the RMB menu on parameters. In general though, multiparm parameters are different then regular parameters. They behave similarly but you don't get a lot of control of them. If you create a few instance, notice they don't show up in the Edit Parameter Interface window other than the base instance parm you can use to set the block up. There's not a whole lot of room for customizability because they are pretty frail and easily destroyed.
Hey here ! It's been 10 years ! And i'm looking for this. Can we today hide multiparm's parameters indivisually ?
I'm currently creating a Dropdown menu of the instances of my Multiparm. And for visibility/clarty and i only want to show the current instance. is it possible today ?
thank you !
15 years now, and I guess it's still not possible?
Like this?
2025-08-05 00-35-26.mp4 (1.7 MB)
