I am using houdini to model the prototype of an RC-vehichle we are building. Houdini is great for modeling physical conditions like drag, gravity, friction etc., but now that we're actually building the thing in real life I need to determine the volume and surface area of each part.
Is there a straightforward way of doing this?
How to calculate volume and surface area of models
19722 4 1-
- epsilonzero
- 3 posts
- tamte
- 9573 posts
you can use
Measure SOP
it can compute Area or Volume per primitive as Primitive attribute
then to get Area/Volume of the whole input mesh you need to append
AttributePromote SOP
and set it to
Original Name: area (or volume)
Original Class: Primitive
New Class: Detail
Promotion Method: Sum
then you can find Detail Attribute of the same name on your geometry and it will contain Area/Volume of the whole geometry
Measure SOP
and set it to
New Class: Detail
- epsilonzero
- 3 posts
- tamte
- 9573 posts
not sure if straightforward enough but you can
create font SOP
in text parameter write some expression like
Volume : `detail(“../null1”, “volume”, 0)`
../null1 is the path to SOP which contain Detail Attribute named “volume” and it's value will be returned by detail() expression
create font SOP
- epsilonzero
- 3 posts
