Draping an object on or wrapping it around another?
7403 4 1-
- talos72
- 112 posts
What is the best way to drape an object on another. Say, I want to use a grid to use as a sheet to be drapped over other objects. I do not want to animate it. It is just for modeling purpose. I have a room full objects and want to hang drapery and throw drapery on certain objects. I have used a spring sop and locked it in frame, but it will not render in the final render.
- deecue
- 412 posts
you might be able to do it with a curve clay sop…not completely sure though.. might have to play with it.
heres a tut on it tho. from the modeling section.
http://www.sidefx.com/community/learn/modeling/legacy/curve_clay_screw4.pdf [sidefx.com]
hth,
dave
hth,
dave
Dave Quirus
- RobertP
- 48 posts
- tallkien
- 225 posts
- talos72
- 112 posts
