I am using the latest apprentice version at home
at a windows xp machine with a compatiable python shell.
I can not create any node type at all, as soon as I run the function
Houdini freezes. I have tried re-installing the program and the same thing
happens.
any ideas?
python createNode('[anynode]') crashes houdini
5781 5 1-
- diegogarzon
- 17 posts
- graham
- 1926 posts
- diegogarzon
- 17 posts
no that does not work either.
it just crashes, I've have seen this same error posted in some other forums
but no solution has been posted.
the code I was trying was this.
obj=hou.node(“/obj”)
mNode= obj.createNode(“geo”)
but pretty much any sort of node that I put into the createNode parameter
will make it crash
will make it crash
- onowak
- 7 posts
im on windows xp x64.
it happens to me sometimes, too. not all the time. and only if i try to create >100 nodes via python (eclipse/pydev environment)
it just freezes houdini and i have to close the program.
weird thing is, if i reduce the number of nodes i am creating, it seems to work. and then, if try creating >100 after that - it works too.
if i drop all the code into a code SOP, it runs fine as well.
specs
windows xp x64
4 gigs ram
3.0 ghz cpu
eclipse ganymede
pydev (current rev.)
houdini 10.1
specs
windows xp x64
4 gigs ram
3.0 ghz cpu
eclipse ganymede
houdini 10.1
- 0chumpy
- 12 posts
this happens to my script. seems like a threading issue.
edit:
for anyone having the same problem as me, open your hipfile in hython and run the script there.
seems like a GL or GUI issue.
houdini 16.0633, linux mint serena, 15GB RAM, inteli7 2630QM, GTX 560M.
edit:
Edited by 0chumpy - Sept. 29, 2017 22:16:00
- chrism
- 2608 posts
