Houdini Non-Comm License Error - why cant i render?
   9701   1   1
for some reason, whenever i attempt to render an image i get this error:
No licenses could be found to run this application.
Please check for a valid license server host
however, it was my understanding that the non-commercial edition of Houdini would allow me to make unlimited renders with a small watermark.
looking at the License Server info in the Admin Tools, it shows that there are 0/1 Render tokens available.
i was able to make one (1) render.
looking at my Server Information shows everything “in the green”.
i have both Houdini Mater Non-Commerical 10.0 & the Render Non-Commercial Licenses installed.
what am i missing?
would anybody have any insight into what i need to do to make multiple renders?
did i misunderstand the terms of Use of the Non-Commercial version of Houdini?
below is the Diagnostic Information from the Admin tool:
License Administrator output:
Generated on: Sat Jul 03 16:14:58 2010
Local host name: ARMITAGE
Local server code: 14ae09ab
Local ip address: 127.0.0.1
Number of servers: 1
License server name: armitage (armitage)
License server server code: 14ae09ab
Server ip address: 127.0.0.1
Reported host name: ARMITAGE
Reported host ip address: 127.0.0.1
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: Yes
License server version: 10.0.401
May modify server from this machine: Yes
Redundant server keys: 1
Name Code Redundant Connected Transmission OK
armitage 14ae09ab no - -
License Administrator version: 10.0.401
Http proxy host: (none)
Licensing options file: CPROGRA~1/SIDEEF~1/HOUDIN~1.401/houdini/Licensing.opt
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
27a54516 Generic Houdini-Master-NonCommercial 10.0 0/0 23-oct-2009
+.+.+.+ armitage (license known to: armitage)
=== This license has expired ===
c5546c06 Generic Houdini-Master-NonCommercial 10.0 0/0 23-mar-2010
d67e1d67 Generic Houdini-Master-NonCommercial 10.0 0/0 23-apr-2010
145e71b9 Generic Houdini-Master-NonCommercial 10.0 0/0 25-may-2010
75442a17 Generic Houdini-Master-NonCommercial 10.0 0/1 22-jul-2010
=== All licenses are in use ===
7ca062a4 Generic Render-NonCommercial 10.0 0/0 23-oct-2009
b9821f4b Generic Render-NonCommercial 10.0 0/0 23-mar-2010
3ff167a3 Generic Render-NonCommercial 10.0 0/0 23-apr-2010
1e9cb140 Generic Render-NonCommercial 10.0 0/0 25-may-2010
45e3d3f3 Generic Render-NonCommercial 10.0 0/1 22-jul-2010
sesictrl -i output:
—– SERVER armitage ——–
Lic 27a54516: 0 “Houdini-Master-NonCommercial 10.0” Generic 23-oct-2009 +.+.+.+ armitage
Lic c5546c06: 0 “Houdini-Master-NonCommercial 10.0” Generic 23-mar-2010 +.+.+.+ armitage
Lic d67e1d67: 0 “Houdini-Master-NonCommercial 10.0” Generic 23-apr-2010 +.+.+.+ armitage
Lic 145e71b9: 0 “Houdini-Master-NonCommercial 10.0” Generic 25-may-2010 +.+.+.+ armitage
Lic 75442a17: 1 “Houdini-Master-NonCommercial 10.0” Generic 22-jul-2010 +.+.+.+ armitage
36867 by ARMITAGE Jul 03 15:58
Lic 7ca062a4: 0 “Render-NonCommercial 10.0” Generic 23-oct-2009 +.+.+.+ armitage
Lic b9821f4b: 0 “Render-NonCommercial 10.0” Generic 23-mar-2010 +.+.+.+ armitage
Lic 3ff167a3: 0 “Render-NonCommercial 10.0” Generic 23-apr-2010 +.+.+.+ armitage
Lic 1e9cb140: 0 “Render-NonCommercial 10.0” Generic 25-may-2010 +.+.+.+ armitage
Lic 45e3d3f3: 1 “Render-NonCommercial 10.0” Generic 22-jul-2010 +.+.+.+ armitage
51712 by ARMITAGE Jul 03 16:06
Serv armitage 14ae09ab
redundant: no
connected: no
transmission successful: no
hserver -l output:
licenses file:
C:\WINDOWS/keys/licenses
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 123 Front St. West, Suite 1401
# Toronto, Ontario, Canada
# M2J 2M2
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 23:57:42 09/22/09
SERVER armitage 14ae09ab bdca80f9c8dc48daddc2bf2acfd5323df0172005f949a1
# Key installed 23:57:44 09/22/09
LICENSE Generic Render-NonCommercial 10.0 1 23-oct-2009 +.+.+.+ armitage \
7ca062a4 4GFtpCqurhN74kU3GvODRRzC5cAmLz5MYJOIn0WWr5wjI6L7CsqXwv2
# Key installed 23:57:46 09/22/09
LICENSE Generic Houdini-Master-NonCommercial 10.0 1 23-oct-2009 +.+.+.+ \
armitage 27a54516 \
9OzAbyF207KNWuh6boXtV8G0TzGGY0bIZg8ftR39WVFZWHzRVB@Ita2
# Key installed 13:44:00 02/20/10
LICENSE Generic Render-NonCommercial 10.0 1 23-mar-2010 +.+.+.+ armitage \
b9821f4b 1+RD4fvylWZebEtjQ0jrYOHx7NnSUqDJEc+yVQ0YlwrEsxaaMC+Mvo1
# Key installed 13:44:02 02/20/10
LICENSE Generic Houdini-Master-NonCommercial 10.0 1 23-mar-2010 +.+.+.+ \
armitage c5546c06 \
jWQxLs60WTKL3ij3EgGaxv5GGeIyH2vFoWWA7O+pSpiytX73fyr1mI2
# Key installed 01:40:06 03/24/10
LICENSE Generic Render-NonCommercial 10.0 1 23-apr-2010 +.+.+.+ armitage \
3ff167a3 ihQZS1eTjiqeTun1L@gPxtLWooMqtRw8cNRl58+LD34TiQoszDwf4Z2
# Key installed 01:40:08 03/24/10
LICENSE Generic Houdini-Master-NonCommercial 10.0 1 23-apr-2010 +.+.+.+ \
armitage d67e1d67 \
JAEbZShWRJuqdR8BW+abBMHKFj6yuvEgrZlnf6kne0nL0+tvdEwrrO2
# Key installed 13:06:35 04/24/10
LICENSE Generic Render-NonCommercial 10.0 1 25-may-2010 +.+.+.+ armitage \
1e9cb140 RhzzNdVWYiS3GBnkzvB+9HgZtJMaEhJrM7MvdC8@xcFuxHrE@oDagF3
# Key installed 13:06:36 04/24/10
LICENSE Generic Houdini-Master-NonCommercial 10.0 1 25-may-2010 +.+.+.+ \
armitage 145e71b9 \
TNTR0+I6n@cOwqXsfbCTNxk30nd0qAVse64tCmS0nDtY9ucBn26Hqz0
# Key installed 19:55:50 06/22/10
LICENSE Generic Render-NonCommercial 10.0 1 22-jul-2010 +.+.+.+ armitage \
45e3d3f3 LW5aPt7FmV2YqDZ1HKFKlrcSg75SIMJUUkExkWoloCzM@aLtfBQgtM1
# Key installed 19:55:52 06/22/10
LICENSE Generic Houdini-Master-NonCommercial 10.0 1 22-jul-2010 +.+.+.+ \
armitage 75442a17 \
MmAbGP3MWFX0WrhQNedrvtfPO7ieBbyMMjZXJzUd18W0vgqTTBfxXJ2
I had a similar experience yesterday (HD version), Houdini failing to connect despite the firewall being set up correctly. Re-installing Houdini restored connection to the server and all was well again.
Your first assumption is correct - there are no limits to the number of renders you can make in Apprentice - it's just limited functionality.
