How to delele particles coming from RealFlow?
   4737   2   0
Hi people,
I'm doing some experiemnts on Realflow particles inported into houdini11, what I'm trying to do is select particles inside a geometry and delete them.
What's the best way to do this?
Thanks everybody in advice.
hey
you can use a group sop first to create a point group, connect you geometry to the second input on the group node, and use group bounds(Bounding Object), then delete by group afterwards
bit slow but should work!
jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
thanks jason!
my gap was in the Bounds optin, now evetrithing works
