line segments
   5909   4   2
say you have a line with 6 points, is there a way to break up a line into different segments so you can access primitive numbers? im thinking maybe some expression in a group sop?. any advice would be helpful thanks a lot.
Have a look at the ADD sop. It has the option to delete all geometry except the points. Then on the polygon tab you can recreate the curve so that it consists out of 5 primitives. Then you can access the primitive numbers. If you want to keep the original curve you can use an ATTRIBUTETRANSFER sop to copy anything you want back on the orignal curve.
Hans
thats great thanks a lot
Put a carve sop, set first U = 0, second U = 1
In Breakpoints tab check, “cut at all internal U breakpoints”
thanks kuba that works really well
