I guess it could be a graphic driver issue. I think you should provide professionals more info about your system.
I got a segmentation fault error on startup too on my notebook, and i solved it reinstalling laptop vendor official graphic drivers (downgrading from ATI's new ones).
I'm getting this issue too. I have run previous versions (10 I think) of Houdini without problems. The splash screen of Houdini master shows but then Houdini console pops up with “2224: Fatal error: Segmentation Fault
Saving application data to …”
The number before fatal error seems to vary each time.
Apprentice license. Houdini 11.0 Build 504
System information: Processor: Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz (1662 MHz) Operating System: Windows Vista (TM) Home Premium, 32-bit (Service Pack 2) DirectX version: 11.0 GPU processor: GeForce 8400M GS Driver version: 258.96 CUDA Cores: 16 Core clock: 400 MHz Shader clock: 800 MHz Memory clock: 600 MHz (1200 MHz data rate) Memory interface: 64-bit Total available graphics memory: 895 MB Dedicated video memory: 128 MB GDDR3 System video memory: 0 MB Shared system memory: 767 MB Video BIOS version: 60.86.57.00.00 IRQ: 16 Bus: PCI Express x16
Well the only possible solution suggested to me was downgrading my graphics drivers but I wasn't prepared to do this. Hopefully this will get fixed in Houdini some day soon; until then I'm running this version on Linux on the same machine without problems.
So I was trying to install 11.0.504 for win64 and I was getting the hang-up at the splash screen and wasn't able to get any further. I rolled back to 10.0.595 and it works. I'd recommend the roll-back to anyone else having this problem.
The older release is available under the Support Menu at sidefx.com.
