voronoi constant width cell borders
8217 6 0-
- kustaa
- 47 posts
ive been trying to do a shader that would draw voronoi cell borders with constant width ( constant world space width).
my best result so far is by getting two closest point from point cloud(PC1 and PC2) getting the mid point between them(M). then doing a dot product between vector M-P and normalized PC1-PC2 and then thresholding that distance value to get the line. it works allmost beatifully. i get problems on the cell border crossings.
maybe my approach is completely off, any better thoughts?
cheers
Kustaa
cheers
Kustaa
- Pagefan
- 519 posts
- rdg
- 401 posts
Haven't look at pagefan's file, yet.
There's also Stupid Renderman Trick for constant width noise lines:
Constant Width Shaders! by Mach Kobayashi from Pixar Animation Studios
A compiled Houdini version:
http://forums.odforce.net/index.php?/topic/6967-a-shader-each-day/page__view__findpost__p__46797 [forums.odforce.net]
http://renderman.org…mach2006.ppt.gz [renderman.org]
this is not a science fair.
- kustaa
- 47 posts
thanks for your replies Pagefan and rgd!
@Pagefan
i had a quick try with your constant width voronoi but i seem to get the same crossing problems as with my dot based solution. its more obvious with thicker lines.
@rgd
that derivative based “normalization” looks really intresting, i have to take a closer look at it. im afraid that it might have the same problems as the other two approaches. since the crossing problems appear where the pointcloud pair changes. maybe i need to read my points differently
i made again a picture that tries to explain what i think the problem is.
black lines are the cell borders, grey lines show where the pointcloud pairs change and white is the constant width border.
cheers!
@Pagefan
@rgd
cheers!
- rdg
- 401 posts
- kustaa
- 47 posts
i think i got closer to the solution!
instead of considering just a pair of points from pointcloud i need to compare more of them. also it helped alot to write this in vex instead of trying to navigate in vop-wire-jungle.
this is my first shader written in vex an theres some issues that i need to clean up, especially with looping through the points, right now its “hardcoded” to go through 4 points. but i couldnt wait to show it.
surface
voro()
int loop;
int handle;
int success;
float data;
vector pc;
vector oP;
int iter;
oP = ptransform(“space:current”, “space
bject”, P);
handle = pcopen(“/home/vuoriku/Desktop/pc.pc”, “P”, oP, 9999, 4);
loop = 1;
iter = 0;
while( loop != 0 )
vector pc1;
vector pc2;
vector pc3;
success = pciterate(handle);
pcimport(handle, “P”, pc);
//gather first three points
if(iter == 0)
pc1 = pc;
if(iter == 1)
pc2 = pc;
if(iter == 2)
pc3 = pc;
//main loop
if(iter == 3)
vector m1 = (pc1+pc2)*0.5;
vector pm = oP-m1;
float dist1 = abs(dot(normalize(pc1-pc2), pm));
m1 = (pc1+pc3)*0.5;
pm = oP-m1;
float dist2 = abs(dot(normalize(pc1-pc3), pm));
m1 = (pc1+pc)*0.5;
pm = oP-m1;
float dist3 = abs(dot(normalize(pc1-pc), pm));
data = dist1;
if(dist2 < dist1 && dist2 < dist3){ data = dist2;}
if(dist3 < dist1 && dist3 < dist2){ data = dist3;}
loop = success;
iter += 1;
Cf = filterstep(0.03, data, “width”, 0.01);
surface
voro()
int loop;
int handle;
int success;
float data;
vector pc;
vector oP;
int iter;
bject”, P);handle = pcopen(“/home/vuoriku/Desktop/pc.pc”, “P”, oP, 9999, 4);
loop = 1;
iter = 0;
while( loop != 0 )
vector pc1;
vector pc2;
vector pc3;
if(iter == 0)
pc1 = pc;
if(iter == 1)
pc2 = pc;
if(iter == 2)
pc3 = pc;
//main loop
if(iter == 3)
vector pm = oP-m1;
m1 = (pc1+pc3)*0.5;
pm = oP-m1;
m1 = (pc1+pc)*0.5;
pm = oP-m1;
data = dist1;
loop = success;
iter += 1;
- rdg
- 401 posts
