this is the code hou.node(“/obj/cam1”).worldTransform().extractTranslates()
when i type it in python shell, it works fine. but i want it apply to a obj's transform,it denied!
this is the error:
Error: Unable to evaluate expression (
File “<stdin>”, line 1, in <module>
AttributeError: ‘NoneType’ object has no attribute ‘worldTransform’
(/obj/null1/tx)).
python code in obj's tx
4057 5 1-
- luoqiulin
- 326 posts
- symek
- 1390 posts
- graham
- 1926 posts
The code works fine for me and there's no reason why it should be failing assuming your path to the node is correct. The error is a result of it not being able to find your specific node so double check your spelling I suppose. If that doesn't work maybe post a hip file.
- luoqiulin
- 326 posts
- graham
- 1926 posts
- luoqiulin
- 326 posts
thank you very much!!
