I've tried installing Houdini apprentice 11.0.701 onto my ubuntu 9.10 32-bit machine.
Being a bit of a linux newbie I followed these instructions for the installation part:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=14289 [sidefx.com]
that all seemed to work fine,
but when I try to actually run houdini I get this error message:
/opt/hfs11.0.701/bin/houdini-bin: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.11' not found (required by /opt/hfs11.0.701/bin/../dsolib/libtiff.so.4)
I thought at first I might of done something stupid like install 64-bit houdini onto my 32-bit machine, but I hadn't.
Would anyone be able to help?
thanks,
Michael
Apprentice installation difficulties on ubuntu 9.10
4294 6 1-
- michael1
- 15 posts
- Alanw
- 320 posts
- michael1
- 15 posts
- Alanw
- 320 posts
It looks like the tiff image library bundled with Houdini is expecting GLIBC version >= 2.11.
You can find your version of glibc with the following command.
ldd –version
If you haven't done so, make sure you run a full system update. Usually a lot of packages are updated with a fresh install. (especially when the particular version of Linux has been out a while)
If you still get the error I would try the following build.
Linux i686 gcc4.1 (tar.gz)
If that fails we can try some other things to get you sorted.
ldd –version
- michael1
- 15 posts
I appear to be on version 2.10.1
I've tried doing a system update, but it didn't update that particular library.
Also the synaptic package manager tells me the latest version is 2.10.1.
The only thing I haven't tried is updating my ubuntu to 10.04.1 LTS - which the Update Manager tells me is available,
or is there another option available to me?
thanks for helping.
thanks for helping.
- Alanw
- 320 posts
michael1
thanks for helping.
It's no problem.
You should be fine using the GCC 4.1 build for i686.
It's listed as follows on the downloads page.
- michael1
- 15 posts
