Hi, i just want to know , if i have a poly object. Then i want to group it based on the volume (bounding box). So i use a ‘group geometry’ node. if i set entitiy to : primitive , then switch tab to bounding. If i start to resize the bounding box, it starts picking up some poly which ‘inside’ the bounding box volume. But this is not what i'm looking for… i don't want to select partial object. What i want is : if the bounding box NOT big enough to cover the whole object, i want it to pick nothing, it will only pick the whole object if the bounding box is covering the whole obj. So i want to pick the whole object or nothing at all, not picking some poly which is part of the objct.
how to do this using group node?
thanx
how to group obj based on bounding box
9095 3 0-
- metaclay
- 122 posts
- metaclay
- 122 posts
- brianBurke
- 192 posts
- metaclay
- 122 posts
