Hi all, I am trying to emit particles from a voronoi fracture simulation. My first idea was to emit particles from the inside group of the voronoi fracture. But the problem is that the dynamics which is done in the dopnetwork is way down the hierarchy after the voronoi fracture node. And I wanted the particles to only emit after the dynamics. But when I tried putting a delete node after the dopnetwork to delete everything except the inside group, I couldn't. The problem is that when I tried searching for the “inside” group or even typing the “inside” out, the error is that the inside group couldn't be found.
I attached a hip file, to further explain the problem. Hope you guys could help. Many thanks!
