top level of PyhonModule
   5687   8   0
Here is a simple script in my OTL Operator Type Properties:
import inspect
def runFunction():
print inspect.getmodule(runFunction)
runFunction()
when I run this scripts inside Operator Type Properties, it returns “None”.
However, that is not what i expect. I thought I would get at least a “hou” or “PyhonModule” module.
It returns me “__main__” if I run this script in a regular python shell outside houdini. It is the way I want.
Does there anyone know the reason why houdini has a “None” top level and is there any way to cheat houdini, to created a fake temp top level module inside my OTL Operator Type Properties?
Why do you need a top level module?
Wrap a function form other external module code.
the code would be setarrt(module, function_name, wrapper)
so the error message is: “None” object has no attribute function_name
because there is a __main__ top level module when I run the wrap module in a regular Python shell, it runs without error.
Then you can check for None, no?
no, sadly the error message shows up.
“AttributeError: ‘None’ object has no attribute ''functionName”
seems “None” module has no attribute.
I'm not sure I fully understand what you want to do. Do you want to make a function in a different module appear as though it's defined in the code inside type properties?
If so, one way accessing the current module's dictionary is via globals():
globals() = other_function
Of course, if you're already running this from outside a function/method, you could just write:
function_name = other_function
or
from other_module import other_function
from functools import wraps
import inspect
def foo(func):
print “wrap”
@wraps(func)
def with_logging(*args, **kwargs):
print func.__name__ + “ wrapped”
return func(*args, **kwargs)
print “wrapII”
print inspect.getmodule(func), func.__name__
setattr(inspect.getmodule(func), func.__name__, with_logging)
return with_logging
def toWrap(x):
print x + x * x
foo(toWrap)
toWrap(2)
so, run this code outside houdini is okay, but error raised inside type properties.
this will make my question more clear
Ah. One way to do it is to access the globals dict where the function is defined using the __globals__ attribute of the function object:
import inspect
def foo(func):
print “wrap”
@wraps(func)
print “wrapII”
if inspect.getmodule(func) is None:
func.__globals__ = with_logging
else:
return with_logging
def toWrap(x):
print x + x * x
foo(toWrap)
toWrap(2)
Thank you a lot, lucas!
This does help!!
