Hi all.
I have a simple question. (i'm sure - that simple)
Ok. I have Ubuntu 10.04 and Houdini 733. What problem i have:
Step-by-Step guide:
1. create new scene
2. create new Geometry object
3. One click on first “Translate” field. (mean translate x)
4. Start to type some expression like $F * 0.5
5. Stop tying and pres Left Arrow on keyboard
Houdini don't only moving cursor, but also selection mode enabled..
How i can disable this feature?
Houdini and Ubuntu 10.04
3903 5 3-
- live_fx
- 160 posts
- fsimerey
- 279 posts
- live_fx
- 160 posts
- digitallysane
- 1192 posts
You might have enabled something in your window manager that keeps Shift pressed after you press it once. There is this option (in any operating system) to enable a mode (sticky keys I think) in which you press Shift or Ctrl once to activate it and a second time to de-activate it.
http://library.gnome.org/users/gnome-help/stable/a11y-stickykeys.html.en [library.gnome.org]
http://forum.kde.org/viewtopic.php?f=66&t=81120 [forum.kde.org]
Dragos
Dragos
- fsimerey
- 279 posts
- live_fx
- 160 posts
Yes it solved, but.. With strange way:
I used Both Shift combination for switching keyboard layout. If I use other combinations - Alt + Shift - a Houdini input iwork pretty nice.)
Something wrong happening in the system with a button Shift, when I choose to switch keyboard layout with “2 shifts pressed”. The same problem when the window manager - WindowMaker, but there I do not know how to solve.
It does not matter, everything is clear now.
Thank you for your help!
