I am trying to get a “caching process” per every new frame. Something like a “Cache SOP” attached to a network… and every time you press (+) on the time-line to advance one frame forward it stores the result. Then when you scrub between the range that you have already played it plays it in real-time.
Cache SOP will do it, but you know how you just hit the cache button and it stays there totally freezing Houdini until the caching is done.
I can possibly cheat by writing out dummy cache files to the $HOUDIN_TMP but I do not really want to fill the $TMP with crap.
Or maybe there is a way to access and make the Cache SOP do a one frame by one frame cache, with some options that can be scripted later?
Any ideas?
Thanks.
Frame by frame caching (as you playback frames.)
3302 4 2-
- symbolic
- 107 posts
- pbowmar
- 7046 posts
- WhoDjini
- 94 posts
Symbolic
Thanks.
Sorry, but I thought that was the reason for having a /tmp at all… to fil it with crap and delete it when no longer of use. :shock:
If you can't script/program it, it's no good at all !
- symbolic
- 107 posts
Thanks Peter,
Well, I usually try to avoid the cacheSOP since I always forget it somewhere in my networks and it causes a bit of mess
So that's why I did not know about this function. I thought that we always need to press that “Cache” button. Embarrassing
Anyway, I am using it now and it works, as it caches any frame being cooked. Thanks. It is pity that it cannot do subframes.
WhoDjini: Yes you are right, but then keeping track of those files is a bit hard, they keep overwriting each other, there is a need for unique names etc., then you forget to clean them up. Besides, I am always cautious to delete any files with scripts when working inside complex proprietary pipelines.
Live life in chunks.
- symbolic
- 107 posts
