"object merge" by pluging nodes?
   3589   2   1
hi there,
I need to importing geometry to sop level without definig it in the objectmerge node manually…need to be able to define it by pluging it in the object node(Digital Asset]…so that geo name could change.
Any help is appreciated
instead of directly defining SOP in object merge
just type in opinputpath() expression
like
`opinputpath(“..”, 0)` this will give you first input geometry of the direct parent subnet/hda of the object merge node
1 will give you second input geometry etc.
Thanks a lot tamte!
