can I render out a white background?
   11116   5   4
I'm fed up with the black background which is by default, can't I specify its color??
Simply put a solid white texture in the “background image” parameter found in your camera view tab with the same resolution and pixel aspect.
thanks a lot!
is it the only way? can't I specify the background color within houdini ?
You can set a background colour or image in Mplay. Type ‘d’ to open Display Options, Background tab and set the Background Color/File.
After hitting Accept, you have to toggle Transparency which is Ctrl+Shift+t. If you would like the colour you set to be the default, click on the “Save as Default” button in Display Options dialog.
Hope the above helps.
Cheers!
steven
Interesting… I thought that the op: expression would work, but I tried and it didn't. I even found a thread where it's sort of explained why, but it didn't make much sense to me still. Can anybody enlighten me?
Cheers
Toronto - ON
