This could be a stupid question, i'm used to work with a desktop with viewer and network panes, but other people, specially modelers are used to work with only a viewer pane, specially if they came from Maya.
From the viewer pane is easy to add OP's, in OBJ, SOP or another context, but how can i delete de actual OP from the viewer pane? I've tried to use the Delete key but it doesn't work, i can walk around my network with Pag Down and Up but i can't delete the actual OP.
For example this is very handy when you create a new Geometry OBJ, enter in it, now you want to delete the File SOP to create a new SOP instead.
Deleting an OP from a Viewer pane, how?
4892 4 1-
- lisux
- 581 posts
- deecue
- 412 posts
- lisux
- 581 posts
- edward
- 8081 posts
- lisux
- 581 posts
