Hi all.
I have had good success “talking” to houdini through a c#(mono) socket.
It would seem that it is much faster, than using hcommand or hython.
when i send hscript through the socket, there is no problem.
but when I send python command as :
<?xml version='1.0'?><python_statements>print “hello world”</python_statements>
i have a problem :
I can manipulate houdini, but I can not seem to return values back down the socket. The values are however printed in the houdini python terminal
This is not the case with hscript, which works fine.
I would like to get vertex info (position,color,uv)
I know how to do the with python, but as I have mention, I am not getting the return values through the socket
My problem can have two solutions (preferably both) :
1. How do I query vertex attributes using hscript ?
2. How do I make houdini python send outputs through the socket.
I a still learning this stuff, so there are still gaps in my knowledge .
I would really appreciate some pointers on this.
PS : I am on Mac
c# socket with houdini
10761 13 1-
- rom12345
- 22 posts
- omy
- 71 posts
- grayOlorin
- 1807 posts
- rom12345
- 22 posts
I would like to reframe this question as it seems to have gone a little off-topic.
The purpose of my enquiry is to enable Houdini RPC in .NET applications through a network socket.
http://msdn.microsoft.com/en-us/library/system.net.sockets.socket.aspx [msdn.microsoft.com]
one thing that would really help for now is :
How do I query geometry properties(points/polys/etc) in hscript ?
- grayOlorin
- 1807 posts
Hey Rom, I apologize. To answer your second question, you can query attributes on a mesh with the following commands:
point() for point attributes,
prim() for primitive (poly) attributes
vertex() for vertex attributes
For example, point(“../yournode”, $PR, “Cd”, 0) would query the red channel of point $PR
I am not sure about your first question though.
-G
- rom12345
- 22 posts
- grayOlorin
- 1807 posts
- zarti
- 330 posts
- grayOlorin
- 1807 posts
- rom12345
- 22 posts
- rom12345
- 22 posts
- rom12345
- 22 posts
mmmf, I'm not sure what I am doing wrong here.
In the textport :
point(“../box1”, $PT “Cd”, 0)
I get
Unknown command : point
are you sure this is hscript ?
It really should be able to work in the textport, remember I need to send this command from a external application.
In the list of hcommands in the docs, there is no command named point, prim or vert
what am I missing here ?
It would seem that point/prim/vert are expression functions that cannot be executed via RPC
In the textport :
I get
- rom12345
- 22 posts
- grayOlorin
- 1807 posts
