ubuntu 11 install houdini 11.0 no icon
   5136   10   0
no icon in houdini 11 ,when i install houdini in ubuntu 11
out is that
unable to find file “/tmp/tools_select16x16.png:no such file or director”
unrecognized file type “/tmp/tools_select16x16.png:no such file or director”
unable to find file “/tmp/sop_captureoveride16x16.png:no such file or director”
unrecognized file type “/tmp/sop_captureoveride16x16.png:no such file or director”
Try the solution in this thread:
www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=23427
no icon still
help who have the /Ttem/*.png GIVE ONE PLEASE
help help thank thank
Try deleting the files in the ~/houdini11.1/config/Icons dir. They may have been messed up by the original problem.
still no icon the new SVGIcons.cache.serial size is 0
If you run this command, do you get any errors?
$HFS/hsvg/hsvg $HFS/toolkit/samples/SOP/SOP_hdk_star.svg
It should return almost immediately with no output. ($HFS is your install dir for Houdini, if it's not set in your environment).
root@tig-System-Product-Name:~# /opt/hfs11.1.118/hsvg/hsvg /opt/hfs11.1.118/toolkit/samples/SOP/SOP_hdk_star.svg
then out
/opt/hfs11.1.118/hsvg/hsvg: 7: exec: /hsvg/hsvg-real: not found
still no icon
Is the HFS variable defined in your environment? (env | grep HFS) Have you run $HFS/houdini_setup before running Houdini via the command line?
YES WHEN I INSTALL I HAVE RUN THE $HFS/houdini_setup AND houdini_setup_bash AND SET THE $HFS
still no icon
