When I use Home and there are fewer nodes (1-4?), it zooms in to fit everything into view but is there a way to always zoom to 100% without fitting the entire network?
Thanks.
Is there a way to zoom to network view in 100% scale?
4008 7 1-
- magneto
- 131 posts
- cybermax
- 255 posts
magneto
Thanks.
you mean “h” key or what?
If you press right mouse button in network view, there is “Viewing controls”!
https://vimeo.com/user3251535 [vimeo.com]
https://twitter.com/milansuk [twitter.com]
https://github.com/milansuk [github.com]
- magneto
- 131 posts
Thanks, yeah the H key. It zooms to 100% scale which is good, but if there are a few OPs in the view, then it zoom as much as so they occupy the whole view, in that case they appear to be zoomed probably 900-1000%. Just wondering if there is a way to always zoom to 100% scale, regardless the number of OPs in the view.
I checked the right click options before but I will have to look at them when I get home again.
- malexander
- 5287 posts
You'd need something like a “Max zoom when homing” preference, with a reasonable default set. It would have to make exceptions for large nodes, like Global Variable VOPs. To be honest, I'm not even sure what 100% zoom looks like in the network editor - it's designed to be a continually scalable layout, so actual zoom numbers are never used.
- magneto
- 131 posts
Thanks twod, exactly what you said.
I might be wrong but when you have certain number of nodes, homing always seem to have a consistent zoom scale, as the nodes always look the same size. I never worked with VOPs yet so I might be missing some of those behaviors you mentioned.
Internally you guys have some sort of size/scale value though, right? I assume something like 1 for no scale = 100% scale.
- malexander
- 5287 posts
- magneto
- 131 posts
- edward
- 8081 posts
