3delight10 ubuntu11 houdini 11.1
3571
3
0
- tig110
- 16 posts
3delight install ok ,work ok
houdini install ok matra work ok
then set the
HOUDINI_DEFAULT_RIB_RENDERER='3Delight9.0'
HOUDINI_SL_COMPILER='shaderdl'
HOUDINI_VIEW_RMAN='renderdl'
HOUDINI_TEMP_DIR= ‘/root/houdini/houdini_temp’
HOUDINI_RIBSHADER_DIR= ‘/root/houdini/houdini_ribshader’
HOUDINI_RSL_HASHING= ‘0’
use the echo look all ok ,,
but but but
use the 3dleight render in houdini , not work
out error: command exit code:127
help please
Edited by - Dec. 21, 2011 20:56:31
- tig110
- 16 posts
proto_install
but out that
Enter choice: 1
sh: 1: /tmp/pinstall.csh: not found
Re-Installed successfully
Hit enter to continue…
- silvina
- 181 posts
Do you have Apprentice version of Houdini? Apprentice does not allow for 3rd party rendering…
- tig110
- 16 posts
i am use the learning Houdini
