Python QT: How can I create a poly curve with python
   8548   6   3
Hi All,
I'm a newbie (my 3rd day now with houdini) and i like to write my first tool in python.
It should simply give me back some helix and spiral curves.
The helix/spirals functions are working, but I have to set a line and resample as input,
now i like to make this working without any inputs,
but I don't know how to create the initial curve as a polygon curve.
The code snippets here:
http://www.sidefx.com/docs/houdini11.1/hom/hou/Geometry#createNURBSCurve [sidefx.com]
are for Nurbs and Bezier curves.
There is an example for polygons, too:
http://www.sidefx.com/docs/houdini11.1/hom/hou/Face#addVertex [sidefx.com]
But how can I create a simple polygonal curve?
Many thanks for any help :-)
You should consider digital assets (HDA/OTLs) before bypassing Houdini's strenghts with python/QT workarounds.
this is not a science fair.
Hi rgd,
thank you for the reply :-)
Maybe this one is yours (rdg?):
http://www.preset.de/2007/0711/lorenz/ [preset.de]
That's what I'm looking for, except that I have to use a curve + resample as input. I like to generate the curve inside the tool, too.
Make a Python SOP that moves the points to the correct position and put it in an OTL togheter with a Curve and Resample SOP.
Drive, monkey, drive!
matthias_k
I'd say a polygn curve is a polygon that's not closed.
matthias_k
Yeah that's ‘mine’. Lorenz attractors are recursive - a concept not easily implemented in Houdini's native contexts. That's why I chose the python back then.
The math for helix/spirals is easily put into a vopSOP or vex node. That's way faster for larger point counts than python.
Thanks for the help and pointing me in the right direction :-)
I'll try it now with a VOPSOP.
I found something in the forum, too:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=84997&sid=7746b29b506198236f86668e27f84618 [sidefx.com]
A couple times you asked how to create a curve. The line sop will work for this.
