Hey guys I'm a bit stuck on this one and need some help!
I've got a bunch of points that represent places on the earth, they are lat long coordinates, which I've interpreted as x and z positions for the points.
This produces good results on a flat grid, I could say render out the points then use that as a texture map onto a sphere with polar coordinates.
However I want some geometry protruding out of the sphere (earth) based on those point positions.
So I need to somehow wrap those points around a sphere like a polar texture map.
At the moment I can (not very precisely) use ray to project them onto the sphere but this only works for one section, not the whole sphere.
wrap points around a sphere?
8835 4 0-
- jpeggt
- 11 posts
- eetu
- 607 posts
- zarti
- 330 posts
hi ,
this is not so houdinistic , but maybe you can start by moving the whole 2d thing ‘Radius’ far from center . then apply a Bend SOP to create a cylinder . then try to strech ( toward earths poles axis ) using a falloff which doesnt affect the ‘ecuatorial’ points , but merges the ‘polar’ ones , while reproducing the spherical shape .
if that fails , you can use another way ; something i call ‘inverse-uvnggineering’ .
i need to be infront of houdini to try this since from my mobile device , Everything seems Possible .
. but .. ill try .
. but .. ill try .
except the things that cannot be seen , nothing is like it seems .
- jpeggt
- 11 posts
- zarti
- 330 posts
