Copy SOP spacing along curve.
   3842   2   1
Hi all, I'm trying to use the copy sop to copy a sphere along the edge of the nurbs curve (used as template). Works fine except the spheres are bunched up around the corners, I need them equally spaced. Anybody know of a way to do this?
Kind regards,
JT
Try the resample SOP.
It will convert your NURBS curve into Polys but it will be the same shape and you'll be able to control the lengths of each segment.
your a legend. Superhero like even. Many thanks. P.S, sorry for the dual posting, pick the wrong forum the first time. thanks again.
JT
