subframe caches into a file node - help!!!!!
   7587   4   0
Hi All
I am caching geo out of maya with subframes
the formating i am using for frame numbers is myGeoCache.0101.1.obj
how do i get a file node to read this as valid frame numbers?
I have been trying the following expression to no avail:
myGeoCache.`pythonexprs(“%06.1f” % hou.expandStringAtFrame('$FF'))`.obj
ideally i could just use a python expression but I am not having much luck
any ideas?
thanks in advance
Sam Swift-Glasman
Art Director
Five AI
I have solved this issue
this is the crazy expression that i came up with:
myGeoCache.`padzero(4,floor($FF))`.`ifs(strmatch(“*.*”,$FF),substr($FF, 4, 4),“0”)`.obj
my main issue was that when using non-integer frames in houdini, frame 101.0 is called 101 with no decimals, i had to use the ifs expression!
Sam Swift-Glasman
Art Director
Five AI
You can also just multiply the frame number by, like, 100 for write and read.
eg. myfile.`int($FF*100)`.bgeo
thank you jason, this is what i have settled on thanks to yourself and jenny at sesi support. it supports two digits of decimal places
cache.`pythonexprs(“'%04d.%02d' % (int(hou.frame()),int(hou.frame()*100)%100)”)`.obj
Sam Swift-Glasman
Art Director
Five AI
Thanks Sam for this great tip
I'm using Houdini 17 and had to change the quotations to the other way around. guessing they changed it at some point. Just thought id mention if anyone has issues.
cache.`pythonexprs('“%04d.%02d” % (int(hou.frame()),int(hou.frame()*100)%100)')`.obj
