quick question about floating objects on fluids
9497 8 2-
- iwilson2
- 31 posts
Hey I'm a student working on my reel. Right now I'm animating a street getting flooded with water. I have larger geometry (representing buildings) that wont be affected by the water but I want my smaller geometry (representing cars) to get carried away by the flood. I've tried RBD, RBD Breakable and a few other things but I cant get it to work. any tips?
- zdimaria
- 390 posts
- icerust
- 68 posts
hi, i got another question about feedback scale. what does it really take into account if one floats or not? i once touched on realflow where mass of the objects are used to determine if it floats or not. basically, similar to buoyancy, if the object has less mass than the water (1000) it floats and those with more sinks.
thank you
thank you
- zdimaria
- 390 posts
Im no expert, but to my understanding, RBDs wont actually float on top of flips. I believe what happens is that there is a force put on the objects by the fluid that is multiplied by the feedback scale. This is designed to work so that a feedback scale of 1 will apply a reasonable amount of force to an object with the same density as the fluid. I'm sure it is much more complex than this, but to my understanding there is no actually buoyancy.
If you wanted actually buoyancy, or at least something closer, you could try using variable density flips for all of it. (Make an extremely viscous flip with very low density for your RBD)
zak
zak
- cgcris
- 67 posts
- PradeepBarua
- 443 posts
- cgcris
- 67 posts
- PradeepBarua
- 443 posts
- cgcris
- 67 posts
Ok, I got this thanks!
What is the easiest or more efficient way of getting to that initial state?
If I have big amount of particle I assume it could take a long time to get to a certain frame. Is it an option to animate the particle separation in order to cheat it? Maybe upping the res a few frames before arriving to the initial state..
