menu from switch input node names
6701 9 2-
- medendog
- 13 posts
How would I create a menu that controls updates based on the switch it controls inputs node names? For instance I have a switch that has several uv edit nodes that control uv placement so one can choose A, B, C texture swatches on a texture page. I have the Digital Asset copied hundreds of times through a stamp on a switch so If I eventually want to add a texture D, E, and F, I would need to manually update hundreds of menu's. Is there a way to have it update based on how many inputs and names of nodes coming into a switch?
- edward
- 8081 posts
Your HDA menu parameter can have its contents generated via a script.
http://www.sidefx.com/docs/houdini12.0/hom/assetscripts#parameter_menu_scripts [sidefx.com]
- medendog
- 13 posts
- edward
- 8081 posts
- medendog
- 13 posts
what I have so far and can't figure out whats wrong is,
result =
for input_node in hou.node(“/wall/switch_tex”).inputs():
result +=
return result
the hou.Node seems to have .inputs but I can't figure out how to point it at the switch. where hou.node(path) seems to give me the node I want but can't figure out how to get the inputs to that node. I found the example in the help documentation but can't seem to modify it correctly.
result =
for input_node in hou.pwd().inputs():
result +=
return result
result =
result +=
return result
result =
result +=
return result
- koen
- 795 posts
- medendog
- 13 posts
Thanks for your help, but I still can't figure out how to reference the specific switch in the digital asset. everything I try for the “Path” gives me an error.
the help says that path starts with / but not sure if I can then refer to the node such as /switch_tex or if it needs to be ../switch_tex, or /../switch_tex
Also not sure what function would be best to use. it seems like hou.Node.inputs() would work, but can't figure how to point it at the node I want. please help.
- koen
- 795 posts
my houdini crashes when I try to look at your otl.
It sounds like you need to use relative paths. It is very much like a unix filesystem.
Lets say your switch is at “/obj/geo1/wall/swtich1”
and your menu lives on “/obj/geo1/wall”
You can then use hou.pwd() to get a link to /obj/geo1/wall and from then use ./swtch1. For example:
otlNode=hou.pwd()
swtichNode=otlNode.node('./switch')
(or just swtichNode=otlNode.node('switch') )
to use relative paths, use “.” for current and “..” for parent.
Hope that helps.
Koen
otlNode=hou.pwd()
Hope that helps.
Koen
- medendog
- 13 posts
- medendog
- 13 posts
So while the menu now works, I have something like 2640 menu's that it has to run the script each time to generate the menu. and it's starting to run slow and I only have about a 3rd of the menu's updated with the script. would It run faster If I had a script on the switch itself that wrote the menu out to a file, and then all the other menu's read the file for the menu contents, or would reading the info from disk be slower? and If I write it to a file how do I make sure that script that writes the file is executed before the ones that reads the file?
