I exported to file, then turned on the flag in my import_pyrofields node. What I expect to find is that it's loading the files from disk, but it's resimulating the fluid when I click on the timeline. I've attached a simple example file.
1) First Export to file to create the files
2) Close file
3) Open file, check “load from disk” in your /import_pyro_build/import_pyrofields node
4) Try clicking on timeline.
Shouldn't it be loading the file from disk? Am I missing something?
H12 "Load from Disk" for fluids not working?
5175 3 1-
- akim_hobo
- 21 posts
- ZeitG
- 9 posts
- akim_hobo
- 21 posts
- jason_iversen
- 12999 posts
Sorry I haven't looked at your setup; but are you writing out .sim files? If so, be sure to set Timeless on the DOPnet.
