ifd > output not defined (ip by default) -o trouble ?...
   2671   2   1
i exported an ifd sequence without specify the output image.
So by default is ‘ip’ and render in mplay interactively.
When i render in command line with mantra and the -o option, in mplay, the image is what i can excepted, the pic file is created, but is not readable at all, his size is 0 or 4 Ko….
I tested to export another ifd with a path in image output and the pic file is good.
If i can avoid to export again my sequence, it would be helpful
render with H12.0.683
Thanks for your help
-o is for a verbose output e.i. text file with statistic. Kind of pixel art you could perform with that, like:
NanNanNanNan
Segmentation Fault
Overwrite vm_picture goes with the last word in a line:
hth,
skk.
Edited by - July 19, 2012 05:17:26
Oh… shame on me !
thanks SYmek
