if your float attribute is called weight then creating Parameter VOP with parameter name weight and type float will automatically bind to that attribute and will completely ignore value from UI
Indeed, thanks, tamte. However, for reasons that are too complex to go into right now I'd like to use the built-in P attribute - the fourth component of position - in my SHOP, rather than a custom attribute. Do you know how to accomplish this?
