Hi all,
If I want to detect whether a parameter has an expression in it or not, how can I do it? i.e. I want to detect whether a string has a backtick in it::
My string has this in it.
/obj/geo1/file1/filename geo.`padzero(4,$F+32)`.bgeo
And I'm trying to do this:
set valueraw = `chsraw(“/obj/geo1/file1/filename”)`
if( `index($valueraw, “\`” )` > -1 )
echo “This has an expression in it.”
endif
My backslashes print as Yen, for some reason \\
For some reason, no combination of escaping this backtick seems to work. Help me, anyone?
Thanks,
Jason
Braindead:: Testing against backticks (expressions)
5782 5 0-
- jason_iversen
- 12999 posts
- hoknamahn
- 398 posts
Jason, catch it!
http://www.aviajournal.interami.com/tmp/check_expr.hipnc [aviajournal.interami.com]
P.S. Houdini, Houdini… Where is my Perl-like regexps?
f = conserve . diffuse . advect . add
fx td @ the mill
fx td @ the mill
- Mario Marengo
- 941 posts
jason_iversen
Hi Jason,
There's a little trick I use all the time for csh scripts, which seems to work in this case too. Just assign the back-tick to a tmp variable and use the variable in the search statement. That way it is not part of the initial expansion of the expression…. like this:
set tick = `
if( `index(chsraw(“/obj/geo1/file1/filename”), $tick)` > -1 )
endif
Hope that helps,
Cheers!
- jason_iversen
- 12999 posts
Hi Mario,
I did try that yesterday, with no luck. It seemed to screw up when it expands the variable. Did this code fragment work for you?
add: In fact, I've tried all manner of trying to put the entire expression into a variable and running eval() on it. It seems to want to choke anytime your use the backticks to get the result of an expression which contains backticks in it.
Thanks,
Jason
Hi hohnamahn,
Thanks for your help; it seems like there should be a silghtly simpler solution. I'll see what I can do with yours.
add: It seems work if it just do this:
float CheckExpr(string path) {
return index(path,'`')>-1;
..since all I want to do is check whether there are backticks in the expression. A little complicated, but there must be some voodoo going on with escaped (unbalanced) backticks in hscript.
Thank you,
Jason
Thanks,
Jason
Hi hohnamahn,
Thank you,
Jason
- Mario Marengo
- 941 posts
jason_iversen
Hi Mario,
Hmmmm…strange.
Yes, I tried it and it worked OK (H6.1.371, Linux RH7.3)
My little test went like this:
*) Default scene. Toggled auto-gen reflection map on /obj/geo1 and set it to the expression /tmp/test.`padzero(4,$F)`.rat
*) Opened textport and here's what happened:
/ -> opcf /obj
/obj -> echo `chsraw(“geo1/reflmap”)`
/obj -> set tick = `
/obj -> echo `index(chsraw(“geo1/reflmap”),$tick)`
10
/obj -> if (`index(chsraw(“geo1/reflmap”),$tick)` > -1 )
/obj -> echo “This has an expression in it.”
/obj -> endif
Which lead me to believe that it worked, although it's not the *exact* same test as yours… so let me try yours…
*) Added a file sop inside geo1 with an expression string for the file name
*) And here's the textport dump, continued from before:
/obj -> echo `chsraw(“geo1/file1/file”)`
/tmp/test.`padzero(4,$F)`.bgeo
/obj -> if(`index(chsraw(“geo1/file1/file”),$tick)`>=0)
/obj -> endif
/obj ->
So it *seems* to work…
Could it be a version/environment thing?
- jason_iversen
- 12999 posts
I wonder.. I'm on Houdini 6.5.71 on RH9.
Thanks for checking it out..
Oh wow; it works very (erratically) for me now; after several false starts. I think its hanging on by a thread. (like all my scripting)
Thanks Mario! I appreciate your and hoknaham's help.
Take care,
J
Take care,
J
