ramp random
   8441   11   0
Hello everyone, I wonder if it is possible to create a ramp random inside Houdini. I create a grid, and want to delete prims by random, but less top, more down. Hope some one can help methanks a lot!
ramp random question.hip (59.0 KB)
You can color you primitives using a color, and than create a group geometry that selects by color, than delete this group, I'll have a look and get back to you.
This gives control by group based of color, so you can change the ramp, you could automate it by having the ramps range change based on the geo (So if it was bigger it would stretch over the size), but this is good for now, If you don't know where to go from this, I might spend a bit more time on it.
ramp_random_question_1992.hip (79.5 KB)
thank you very much I check the file, but find it is a little bit not what I seek. Not only a ramp I want to create, but a random deleting is also the goal. The density of deleted prims are based on the ramp direction. Hope I express myself more clearly this time But the file is still very helpful and I am very appreciated.
If you can figure out how to use two attributes to do the deleting you could multiply the random deletion by the ramp, like I said, if i get more time I'll further look into it.
thank you very much, I have worked it out! The method is really useful.
Can I see the hip file? Wouldn't mind seeing how you did it in the end.
ok, here is the file.Have fun.
ramp_random_question_fixed.hip (87.0 KB)
Thanks, Keen to see how you patched the methods together!
*Edit*
Very nice indeed, what was this for?
This can also be done with a simple vop which does the math and then promoting the attribute from points to primitives. It's faster (even though that doesn't really matter much in small scale example), and if you replace the random with some noise inside, you get much more control over what's going on in there.
ramp_random_question_vop.hipnc (99.8 KB)
Technical Director @ Kredenc
www.mkolar.com [mkolar.com]
That's definitely the way to go.
To Delight0092 what was this for?
I am working on an architecture project, the mission is to insert 25000 old bricks inside 60000 bricks, in ramp random way. So I have to do this
To mkolar:
The method is great, I never considered using VOP. But the problem of my project is the deleted number of my prims are fixed. But it is still great way to solve the case. Thank you.
