Camera animations,
Hello, is there a good tutorial about camera animation?
Because I find these very difficult to setup. I get strange rollovers
Ton
Camera animations
11716 4 1-
- galinaton
- 19 posts
- zdimaria
- 390 posts
Not sure what you mean by rollovers, but if you shift click on the parameters it will open up the channel editor and you'll see that by default all animation is set to bezier if thats what you mean.
Not sure how everyone else works, but I like to add a null or two above the camera and animate there. This doesn't really matter so much, but it's much easier to get a more realistic rig that way. I don't know of any tutorials though.
- galinaton
- 19 posts
Thanks zdimaria, for your answer.
Very nice work you make.
What I mean is, moving the camera around from one point to another point in the camera makes a wave movement.. also the cameras are very difficult to see in the viewports, top, side views. Can Houdini display the motion path of the cameras in the viewport, side, topviews.
For a turntable animation I have also used a null for the camera to look at, this works good.
when I want to fly over and in a building is this also done with a null ?
- milospejak
- 30 posts
this should help
http://forums.odforce.net/index.php?/topic/8085-visualise-camera-path/ [forums.odforce.net]
mpejak
- galinaton
- 19 posts
