Connect two vertex
   5691   1   0
What would be way to connect (create edge in-between) two vertex on polygon?
Here is situation, I want to connect 32 and 28.
https://www.evernote.com/shard/s234/sh/1013ff6f-8c8e-4d07-b414-ae07957df5c5/4a58ec7b07e63a3b895aeb7314718a0a [evernote.com]
For some reason edge divide does not do all the way around, and now I need to fix it. But do not know how.
to make them one point use a fuse sop.
to add a line between them use an add sop set to polygons ->by group -> ‘28 32’
then use a fuse sop set to 0 to make this line use the points that were there.
to make the edge sop go around i believe you will have to use the first method.
