pcopen find farthest point from sampled ones
   4850   2   1
afaik pcopen finds closest points to given one.
im need to find the farthest one from found.
for example pcopen finds 10 closest points - from that 10 points i need to get P-attrubite from farthest one.
can someone help me please?
i found point cloud farthest node in vop, but it finds a farthest distance to point - im need to get an P-attribute, not just a distance.
thanks.
the points returned from pcopen are queued by distance so if you take the last one it will be the furthest one
to get its index you can use ( pcnumfound VOP - 1 )
then just import any attribute from it using pcimportbyidx
and don't forget to close your pcloud afterwards since you weren't iterating through all queued points
tamte
its working!
thanks!
