"merge node" mis-match of attribute how correct t
   6073   2   1
hi everyone,
i have a problem and don’t find solution, i searched on forums, but nothing…
i created multi geometry in my node, each have an UV node..
then, i merge all.. at this moment, all is perfect, but when i connect a last geometry to my merge node, all my UV are destroyed.. and in my merge node, i have this message:
A mis-match of attributes on the input was detected.
Somes attributes values may not be initialized to expected value.
Now, i don’t know how use “attribute” node.
Someone can explain me how make for correct this problem?
Sorry for my english..
See you
Best regards.
probably the same as here
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=27644 [sidefx.com]
hi,
wow.. it’s perfect..
it’s only this little setting..
thank you very much..
Best regards
