objects randomly instancing / copying through a switch
7610 4 0-
- roughsporty
- 191 posts
- edward
- 8115 posts
- circusmonkey
- 2624 posts
- roughsporty
- 191 posts
- tamte
- 9461 posts
for instancing you can use instance string attribute containing path to object for each point
for copying you need to use stamping to switch the input of the Switch sop
here is the example of setup where you can plug any number of inputs to switch sop and they all will be used to randomly distribute over the points
of course you can combine those methods in one file where copying will be used to preview proxy versions of objects in viewport and instancing will be used for render
