Fluid Object - Surface visualization
   2996   2   1
I just have one question, sorry for creating a topic only for this…
When I use the “Emit Particle Fluid” tool, I do not see particles, like in this tutorial :
http://www.sidefx.com/index.php?option=com_content&task=view&id=2157&Itemid=262 [sidefx.com]
In the surface tab of the guides in the fluid object, there's is no such thing like “Sphere, Sprites, Grain, Particles”, like in the FLIP Object. So can I see particles for visualization ? Or this is not the tool to use for emitting fluid particles ?
Thanks,
Lewul.
https://vimeo.com/obreadytom [vimeo.com]
Go to AutoDopNetwork and select your flip fluid object node, on Guide tab next to visualization, there is particles tab. On that tab select the desire type of visualization that you want from the drop down list.
Make sure you have particles check box on, on visualization tab and you might want to turn off visibility of your source object on scene page.
Thanks for your answer ! The problem is that at home I can't have the fluid I got yesterday, without particles I mean :?
I'll check this Tuesday !
