Rigid bodies infinite creation problem
   3028   2   0
Hello again everyone, can you help me with something here? I imported an object and set it to be a rigid body. Since what i wanted was a rain of intances of the same object i set the creation frame to this expression
if ($F%10==0, $FF, 0)
In order to instantiate them in random positions i set both X and Z initial values for this
fit01(rand($OBJ),-1,1)*20
now my problem is that, when i run the simulation they're not being randomly distributed around as i expected instead they are, yes falling in random X,Z positions but in a diagonal to the grid…
What am i missing here? Can you help me please? Thank you all…
Cheers!!!
houdini problem.png (219.0 KB)
You are entering the same seed to both your rand() functions. Change the seed to eg. $OBJ*7.7 on the Z axis, that should help.
Quick and efficient. Thank you very much. I understand what i was doing wrong now, it makes sense… Thank you so much…
