Low cost CPU: Xeon E3-1230v2 - Any one experiences/opinions?
   4974   4   0
Thinking about a “low” budget workstation solution.
Has anyone experiences or at least an opinions to
the Xeon E3-1230v2.
Is it enough for non professional use?
Would be so useful if anybody could help me, because I´m no hardware expert at all!
Greetings
Gerd
Processor Number E3-1230V2
# of Cores 4
# of Threads 8
Clock Speed 3.3 GHz
Max Turbo Frequency 3.7 GHz
Intel® Smart Cache 8 MB
Max Memory Size (dependent on memory type) 32 GB
I am not sure but unless you are gonna go dual cpu then its good to have a xeon setup, but some xeons are not configured to work with a second one. You need to check but I think this cpu doesnt work on a dual socket board with another next to it.
In that case, it doesnt worth it, If you are going for a new setup, then you should definietly go Xeon, but a cpu that is around i7 or i5 performance with hyper threading on a dual socket board. You can buy the pair later in the future
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
@trice, i believe you have this backwards. tmk i7s do not support dual cpus on one board while xeons do
This xeon can work only alone, not in 2 cpu system. If the budget allows, then I`d go for i7-3770k. This will allow you to get 4.5 Ghz speed under 30$ cooler for 24/7 without any problems. However it depends on your local prices. The one you`ve chosen is still very nice one, so if you can't spend more, then go for it. But the new xeon can't be overclocked
zdimaria
lemme correct my postt,I meant to go with a xeon cpu that has similar perofrmance to i7 or i5 but that specific Xeon does not support dual setups.
Head of CG @ MPC
