Shatter piece names
   3785   3   1
I'm doing some tests breaking a geometry using Shatter. I got something like 500 pieces, I know that using blast I can select each one of that pieces but there's a easy way to know which piece is which without testing with blast? Something like put a text in each piece with it's name? Or some other trick that can speed up the process?
This should do the trick: http://www.sidefx.com/docs/houdini12.5/basics/attributevisualization [sidefx.com]
You might wanna try Houdini's Inspection mode. Let's you inspect info about geometry directly in the viewport!
http://www.sidefx.com/docs/houdini12.5/basics/inspection [sidefx.com]
Francisco Rodriguez
Effects Animator | Walt Disney Animation Studios
Thanks fxrod and cubiccube, both methods worked the way I needed.
