"Cut" mesh on UV wrap?
   5958   5   2
Is it possible in Houdini to texture a surface and then have verts/edges generated on the underlying surface mesh at UV wrap points?
Basically what I want to do is pack all my textures into atlases and that doesn't support tiling. So I need to add geometry to hold the UV coords when it wraps.
Thanks,
Brett
Sorry
ops:
Please explain more clear ,I can't understand your meant !
Can you give me another example ?
:cry:
Rabiee.Sadjad@Gmail.Com
I'm guessing he means to tile a portion of a tpage over neighbouring polys, I.e. needs to split the adjoining verts? ( Fuse->Unique Points )
Sorry, I wasn't clear.
I want to generate a mesh based on UV coordinates. Take a square of a given size, tile a texture onto it. Now run an operation that cuts the mesh so that the texture is now face mapped instead of repeated.
Does that make sense?
Basically I need all UV coords to be in the range of 0->1. So if you tiled a texture and it had UV of 2, it would cut the mesh at 1, then reset the UVs to be 0->1 again.
Start: 0->2, after operation, 0->1 + 0->1 with a new edge at the boundary for the UVs to “stick” to it.
I gotcha, you want to dice based on UV extents of 0-1.
I expect there's a few ways to achieve this… I'd do it in python, but you can probably also do do it with VOPs, in combo with a Divide or Carve SOP.
You want to compare each primitive's edge verts/points for values that cross outside the 0-1 range (i.e. 0.9 to 1.2), mark the prims with attributes containing the U/V splicing distance, then apply the divisions per primitive with a Divide or Carve (each would require a slightly different approach…Divide probably the simplest).
Once that's done, you can seperate the points with a Fuse SOP -> Unique Points.
Then you need to iterate through all the primitives again, fixing their UVs to fit in the 0-1 domain. This may be simplest (and fast) with a Point Wrangle.
You may have to do some tidying up afterwards as, depending on what you're applying this to, you may have quite a lot of excess geometry and attributes. Also, while it should work ok for flat surfaces, it may not work on non-planar surfaces (nor non-quad prims).
(Alternatively, you could just build a new set of quads based on UV bounds)
@AdamT
Yes, exactly! I will try to make a simple test along this line of thinking. I'm no Houdini guru so it will be a fun challenge!
Thanks for taking time to point me in the right direction :-)
Brett
