Then I press F1 i get following errors
Houdini console:
aseHTTPServer.py“, line 340, in handle
self.handle_one_request()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\httpserver.py“, line 431, in handle_one_request
self.wsgi_execute()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\httpserver.py“, line 287, in wsgi_execute
self.wsgi_start_response)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\httpexceptions.py“, line 636, in __call__
return self.application(environ, start_response)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\evalexception\middleware.py“, line 184, in __call__
return self.debug(environ, start_response)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\evalexception\middleware.py“, line 201, in debug
return method(environ, start_response)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\evalexception\middleware.py“, line 218, in mochikit
return app(environ, start_response)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\urlparser.py“, line 484, in __call__
fa = self.make_app(full)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\urlparser.py“, line 490, in make_app
return fileapp.FileApp(filename)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\fileapp.py“, line 178, in __init__
content_type, content_encoding = self.guess_type()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\fileapp.py“, line 186, in guess_type
return mimetypes.guess_type(self.filename)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\mimetypes.py“, line 294, in guess_type
init()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\mimetypes.py“, line 355, in init
db.read_windows_registry()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\mimetypes.py“, line 259, in read_windows_registry
for ctype in enum_types(mimedb):
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\mimetypes.py“, line 249, in enum_types
ctype = ctype.encode(default_encoding) # omit in 3.x!
UnicodeDecodeError: ‘ascii’ codec can't decode byte 0xe0 in position 0: ordinal not in range(128)
Exception happened during processing of request from ('127.0.0.1', 2543)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\httpserver.py“, line 1062, in process_request_in_thread
self.finish_request(request, client_address)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\SocketServer.py“, line 334, in finish_request
self.RequestHandlerClass(request, client_address, self)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\SocketServer.py“, line 649, in __init__
self.handle()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\httpserver.py“, line 436, in handle
BaseHTTPRequestHandler.handle(self)
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\BaseHTTPServer.py“, line 340, in handle
self.wsgi_execute()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\site-packages\paste\evalexception\middleware.py“, line 209, in media
init()
Exception happened during processing of request from ('127.0.0.1', 2544)
self.handle()
self.wsgi_execute()
init()
File ”C:\PROGRA~1\SIDEEF~1\HOUDIN~1.21\python27\lib\mimetypes.py", line 249, in enum_types
– 1 ——————————————————–
And in brouser that opens but shows :
URL: http://localhost:48626/ [localhost]
Module paste.evalexception.middleware:306 in respond
<< try:
__traceback_supplement__ = errormiddleware.Supplement, self, environ
app_iter = self.application(environ, detect_start_response)
try:
return_iter = list(app_iter)>> app_iter = self.application(environ, detect_start_response)
Module houdinihelp.wsgi:393 in dispatcher
<< # environ = path
if static:>> return app(environ, start_response)
Module houdinihelp.wsgi:155 in wikiapp
<< wikify = page.path != spage.path
resp = _response(manager, indexdir, req, page.path, spage,
wikify=wikify)
return resp(environ, start_response)>> wikify=wikify)
Module houdinihelp.wsgi:30 in _response
<< resp = webob.Response()
ext = util.extension(path)
mtype = mimetypes.guess_type(path) or “text/plain”
isdebug = ext in (“.srch”, “.wiki”)
nocache = nocache or (req.environ.get(“HTTP_PRAGMA”) == ‘no-cache’)>> mtype = mimetypes.guess_type(path) or “text/plain”
Module mimetypes:294 in guess_type
if _db is None:
init()
return _db.guess_type(url, strict)>> init()
Module mimetypes:355 in init
<< if files is None:
if _winreg:
files = knownfiles
for file in files:>> db.read_windows_registry()
Module mimetypes:259 in read_windows_registry
<< with _winreg.OpenKey(_winreg.HKEY_CLASSES_ROOT,
r'MIME\Database\Content Type') as mimedb:
try:
with _winreg.OpenKey(mimedb, ctype) as key:>> for ctype in enum_types(mimedb):
Module mimetypes:249 in enum_types
<< break
try:
except UnicodeEncodeError:
pass>> ctype = ctype.encode(default_encoding) # omit in 3.x!
Is There any way to fix this?
H13 Help problem
14426 5 1-
- DimitryB
- 4 posts
- chrism
- 2613 posts
Log a bug.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
Chris McSpurren
- RomanM
- 2 posts
this problem - UnicodeDecodeError: ‘ascii’ codec can't decode byte 0xe0 in position 0: ordinal not in range(128)
fix bug - edit file ….Houdini 13.0.222\python27\lib\mimetypes.py and
try:
pass
These lines in mimetypes should simply be removed.
try:
pass
Edited by - Nov. 6, 2013 13:06:06
- DimitryB
- 4 posts
- mchaput
- 515 posts
- alzosmol
- 10 posts
