Python Command to Create PythonModule Event Handler
   4197   2   1
I'm looking for a way to create a “PyhtonModule” event handler in a fresh HDA using Python. So far I have not found a way of doing this.
I am able to create a new section in the HDA containing Python code.
However, if I want to access the code, I must manually create a PythonModule Event Handler and add:
import toolutils
bar = toolutils.createModuleFromSection(
‘bar’, kwargs, ‘bar_PythonModule’)
if I want to access that code.
However, this sort of defeats the point.
Is there a way, using Python, to creating a PythonModule Event Handler and modify its contents?
asset_definition = hou.node(“/path/to/node”).type().definition()
section = asset_definition.addSection(“PythonModule”)
asset_definition.setExtraFileOption(“PythonModule/IsPython”, True)
section.setContents(“def foo():\n print ‘test’”)
Wooo Hoo!
That worked like a charm.
I had not even thought to look at the “setExtraFileOption” function.
Thank you so much!
